4.1 Brim when 2nd object is nearby
Hi
I add often a small object to critical corners and edges of a model to improuve the adhaesion to bed and avoid warping.
S3D 4.01 and further versions had no problem to cross over the brim lines so that the space between the 2 objects was closed.
S3D 4.1 exclude this space and let it open. Instead filling the gap it add a very small point without any sense.
How to solve this?
GER
S3D-Alex
Re: 4.1 Brim when 2nd object is nearby
Can you please post a Factory File for this?
No problem, here ist it as attachement.
Also some pics to demonstrate what I mean.
Version 4.10; distance between both objects is 2 mm, with 3 mm it is similar
Version 4.01; distance 3 mm
401_Brim 3 mm.png (34.56 KiB) Viewed 2275 times
another try to attache ...
Brim-2-objects.factory
(15.58 KiB) Downloaded 253 times
S3D-Alex
Thank you to everybody for reporting this and including all the files to help us to reproduce the issue! I was able to reproduce this here in our office and I have documented these findings for our development team.
