The external infill pattern can really affect the beauty of your 3D print's top surfaces.
Using the current system in Simplify3D, we have a few options on how to create external infill. Concentric infill can be quite beautiful in some cases. The other option, Rectilinear, is adjustable by angles defined in the "Infill Angles" section. That's about the limit of our control. The Rectilinear external infill pattern is unfortunately tightly tied to the internal infill pattern. They can't be decoupled. It's the same pattern, but with 100% infill. If you're using 0 and 90 angles for your internal infill, that's what the external will use as well. What works best for the internal infill doesn't always look nice as external infill.
We currently can either have concentric, or rectilinear external infill. Concentric is nice as is, and shouldn't be changed. Rectilinear needs to be decoupled from the internal infill. For external infill, the infill percent is always 100%. This is as it should be.
I would like the ability to make custom external infill patterns. I'm not sure what the proper way to do this is.
If the pattern could be totally customized by the user, that would be fantastic. You could provide a few defaults built-in, but allow the user to really go crazy with the patterns.
I've often thought that it would be nice to have an external infill pattern that mimics wood grain. Another nice one would be a cloth-like stitched pattern. Maybe some concentric cubes. A triangle pattern maybe. I'm sure lots of people will have very interesting ideas for custom infill patterns.
The difficult thing I see in this is how to allow these patterns to be defined. That will really take some thought. Maybe there already exists a file format that has such patterns defined that could be used? The patterns need to be 100% infill, so they can't have empty spots in them. Maybe someone else has a good idea on how to specify the custom pattern?
