JNEWMAN
Newbie Issues with Autodesk Inventor STL to print on Flashforge Creator Pro
Thu Nov 29, 2018 9:21 pm
Good Morning All.
I picked up my printer a Flashforge creator pro, only yesterday, and I am playing around with it made a few prints so far.
I am now looking to print my own designs. However I am struggling somewhat.
The designs that I produced were done so on Autodesk Inventor, and saved as an .ipt file. The dimensions of these parts were built using ANSI Metric mm. When I print these inventor designs, not on 3D Printer but on an inkjet using A4 paper, the designs are to 1:1 scale and have the correct dimensions when measured, so this confirms the designs are indeed correct.
The .ipt files have been saved as an .stl, when I attempted to import these into Simplily3d, it comes up with a dialogue box called Auto Scale Option stating the following message "Part appears to be extremely small and may be in inches format. Would you like to automatically scale to millimetre format? This is despite all elements of the design being done in ANSI Metric mm?
I have tried both options
Selecting Yes seems to scale this up from 10mm to 100mm!
Selecting no seems to think that 10mm is 1mm for the correct dimension, I am guessing?
So what I have attempted so far is to select yes, and then manually change the Z scale from its scaled up 100mm, to the correct 10mm, however despite uniform scaling being selected, it does not scale all features of the design correctly, for example, if there is a 10x10x10mm cube with a circular hole through the centre with a diameter of 5mm, then by imputing the correct Z scale of 10mm results in that hole becoming 4.2mm and not 5mm?
This is really causing me a headache and I would appreciate help.
Many Thanks
NitroXpress
Re: Newbie Issues with Autodesk Inventor STL to print on Flashforge Creator Pro
Fri Nov 30, 2018 12:44 pm
I tried it with a 10x10x10mm cube.
No Problems...
Can you upload your model ?
Frank
Fri Nov 30, 2018 1:18 pm
If all of the work you're going to do from now on all need something doing to it....and it looks as if you're in the process of working out what needs to be done......there is a feature in S3D to always execute one or more changes to every model that is imported.
Here's a YouTube video that explains it: https://www.youtube.com/watch?v=E8ytvwfCn5g
Its worth noting that stl files do not contain any dimensional information....such as being designed in mm or inches, or anything!. There are units.....but no definition as to what those units are. So you'll have to work out the scaling factor first.
Hope this helps....
JNEWMAN
Fri Nov 30, 2018 2:22 pm
I worked it out, its how I saved it as an STL.
There are 2 ways on inventor to save an .ipt as a .stl
The first method is to select export > export as > save an STL this method caused this inches issue.
The 2nd way is to save as 3D printer service this then creates a parameters box showing the dimensions of the part hit save and hey presto it works straight away in S3D. Thanks All
NitroXpress
Sat Dec 01, 2018 11:27 am
Strange...
I use your first method without problems.
Have you adjusted the export options ?
JNEWMAN
Sun Dec 02, 2018 10:59 am
No I did not use the export options, too complicated. I am merely getting up to speed with it, really helps having this community.
Thanks
