Hello,
So I've been searching around and so far, all I can seem to find is a commend (below) for pausing the print at a certain LAYER, but I have not seen a command to pause the print at a certain HEIGHT. Is this possible?
Here's what I have to pause at a certain LAYER:
{REPLACE "\n; layer 22, Z = " "; layer 22\nG28 Y0 X0\nM300\nM25\nG92 E0\nG28 Y0 X0\n; layer 22 "}
Can I replace "Layer" with something that will stop it at a specified height?
Here's the problem: I can pause a single model at layer 20 and it works fine... but if I try to print 2 of those models, it then stops at layer 10. I can try to double that but then it only stops for one model instead of both... so on the other model, it will stop before or after that layer but not on it. Kind of difficult to explain but if you try it, you'll see. This is why I was wondering if it's possible to just stop it at a certain height instead of layer number.
One other thing: I'd like it to go to position X200 Y400 instead of homing. Anyone know what to replace the G28 commands with to achieve this?
Any tips or advice would be much appreciated!
