leonhart88
Plastic weight of each part in build statistics
It would be nice if the build statistics in Simplify3D was able to list out the plastic weight per part rather than a total plastic weight. The Form 2 software allows you to slice each part separately and select which parts properties you want to view, which then shows the volume of that particular sliced part.
This would be nice to have when using Simplify3D as a slicing tool for 3D printing as a service. Currently, I have to slice one individual part, view the plastic weight, and then redo this for all remaining single parts to find out plastic weight per part. Then I have to optimize the parts together to fit as many as I can on the build plate.
Maybe there's already a way to do this that I'm not aware of?
Re: Plastic weight of each part in build statistics
to solve it fast, select the only one asked model for the current process, so the other models won't be sliced and all values are relatet to the only one.
GER
