fabriziodavid
Raft 1st layer width
349/5000
I have a problem with version 4.1.0 and 4.1.1.
The problem is in the extrusion width of the first latyer, when using the raft.
Changing the value of the first layer width in the settings has no effect.
With version 4.0.1 this problem does not occur.
Can you help me, maybe there is some setting that does not sept correctly.
Thank you.
Re: Raft 1st layer width
This was an intended change. Our development team thought that it seemed like overkill to apply the first layer width to the raft, since that is already printed extra thick. Are you having issues with the default raft extrusion thickness?
