My design doesn't have or need supports. When I put the part into Simplify 3D the preview looks correct but when I generate the print it has created random supports. I checked all the settings and can't find why the software is doing this.
It is possible you still have the Generate Support Material option turned on in the Support tab of the Process Settings. If this is not the case please post a Factory File showing the issue. Thank you!
