PhillipM
Different speeds for retraction speed vs restart speed
Just one I think that would help a lot of people with seam issues on S3D - I've noticed if I run a far faster retraction speed, say 60-80mm/s then the seams get much more like other slicers and almost disappear - unfortunately, if you're then running a sticky or flexible material like PET-G or TPU, then feeding back in at 80mm/s on a restart will make the extruder slip as it encounters residual filament in the nozzle from the retraction and the pressure builds just before smooth extrusion - meaning you end up slowing the setting down to 25-35mm/s and getting worse seams just to stop the slippage.
I'd like to see this setting split, into one setting for retraction speed, and another for restart speed, so I could then run say 80mm/s retraction with 30mm/s restart speed, giving much cleaner seems/line ends but without the chance of filament grinding on restart.
Re: Different speeds for retraction speed vs restart speed
Phillip,
Great idea for a new retraction/prime speed setting. In the current software, have you tried using a REPLACE command to change the speed for the prime? If you know the retraction speed and the priming amount, the REPLACE command should be fairly simple to script.
example:
retraction amount = 1mm
retraction speed = 80mm/sec or 4800mm/min
extra restart distance set to 0mm
Your prime sequence in the g-code should look like this:
G1 E0.0000 F4800
G92 E0
so replace it with your own slower slip-free speed
{REPLACE "G1 E0.0000 F4800\nG92 E0\n" "G1 E0.0000 F1800\nG92 E0\n"}
PhillipM
Thanks, I'll give that a shot. Be nice to have it in the UI though as it's not really machine-specific?
Ultrasonic2
So ..to me having two speeds makes sense ..you want it fast pulled out but slow back in ... the slow back in is important to allow the firmament to re heat / Pressure to build .. It becomes a bigger necessity with super long distance traveled and long bowden tubes (big printers)
I managed to get a version of the script you posted to work..
