tonyno
Errant Stitching?
Thu Feb 28, 2019 10:24 am
See attachment. Where is this coming from and can I get rid of it? There is nothing that I can see that it is connecting.
keurig support.factory
(11.32 KiB) Downloaded 15 times
Re: Errant Stitching?
Thu Feb 28, 2019 10:52 am
First question first....its being caused by there being two solid layers set for the top surface. You are always likely to get these extra extrusions as the slicer tries to follow the rules you set where sloping edges are concerned.
Second question - use the Variable Settings Wizard to create a split that leave two layers in the top-most profile, then change the middle profile so there is only one top solid layer. Simples!
tonyno
Thu Feb 28, 2019 8:06 pm
Interesting, and thanks.
Seems like that would be a third/fourth layer, though, but I will investigate.
tonyno
Tue Mar 05, 2019 4:43 pm
Multiple top layers was the issue, but I had to set it to zero to get rid of it completely.
