Hi All,
i have been using S3D quite a lot since November 2018.
Where some items are well organised in the advanced option, there are plenty of settings laying in random places - making new user confused a lot.
Before i get use to the mess (sorry S3D but its true) my learning curve was very steep...
Why there is no sections with all the option to specific feature.
Like on the first layer - its not to bad...
but then...
which options are controlling the next layers ? - that's juts one, for example... there is no infill speed control at all.
Speed tab should only have one option - general speed (as of main speed of the print), then in each section should be a speed control option - this will make it more clear and easy to adjust, as you will know i.e. your infill speed is to fast, so go to infill and change this speed only.
I know it is a bit mess what i wrote now, but i have an idea to organise the whole advanced menu and can do a graphic layout and post it here when i get a bit more time.
Generally - I am asking to make it more consistent for each feature tab.
