The answer is ‘Yes’ you can do it...
This is how I do it - it requires a model (.stl) that can be split into two models, One outer, One inner.
That’s easy to do if you’re a CAD user or have other software that enables Boolean Subtraction/Differencing.
With the two models, simply create two separate process with the Speed/other parameters you want.
A simple example is one I posted for something such as a Threaded feature requiring more Shells than the surrounding material (for Thread tapping or cleaning-up printed threads, as an example…). Look for my post on below link.
viewtopic.php?t=11452&p=45087#p45087
