Hi! I need help with simplify3d scaling… I am trying to print figure as below… In the model external size (marked with red) is 29.214mm and internal circle is 6.4 mm.
Once printed in 100% scale external is 28.9 and internal is 5.0 ☹ once I adjust scale to 101,08 external prints with tiny difference, but internal is still very small. To print internal in right size I need to use 128% scale ☹ but it drives external size far away…
Which settings should I consider to be changed?
Many thanks!
