styldesley
[FIXED] no retraction crashes s3d
Attached a factory file. Generally any object sliced with no retraction crashes s3d (for me). What am I doing wrong? Would like to slice without retraction. Thank you.
factory file.factory
(161.65 KiB) Downloaded 142 times
styldesley
Narrowed down the problem
No retraction on right extruder means crashing s3d. No retraction on left extruder and no crashing. Any object , any profile.
styldesley
Flashforge creator pro 2016 plus
Stock flashforge creator pro profile, with only one change , no retraction on left extruder will also crash s3d. The above factory file is a modified creator pro profile.
Re: no retraction crashes s3d
Works fine for me. No-retraction itself can not be a reason to crash S3D. Version 4.1.1 crashs often without identifiable reason. Close and restart the program and store a factory-file before Prepare to Print. Than it needs only to Open the Factory-file and try again.
The overhang needs support, it seams to flat.
GER
Try the tips suggested by Alex in this thread: viewtopic.php?f=9&t=11924&start=10#p48068
styldesley
4.1.2 fixed crashing with no retraction. No long delay. thank you s3d
S3D-Alex
styldesley wrote: Sat Apr 06, 2019 9:34 am 4.1.2 fixed crashing with no retraction. No long delay. thank you s3d
Thank you styldesley! You beat me to it! This issue has been fixed in 4.1.2. A special thank you to everybody that helped by reporting the problem and helping us get to the root cause. Crashes with retraction visualization while retractions are disabled will no longer be a nuisance.
We are always working to improve the efficiency and seamless nature of our product and your help is invaluable. This fix was one of many that occurred with this new version. Please check out our Release Notes page.
