Infill Failure
I have to print some rectangular blocs as spacer which must be very compact.
Unfortunately the edges of the first print get a layer splitting, a well known problem for greater rectangular objects.
To avoid this I have insert a column to enforce the edge for a slicing test. And the Print Preview shows me the infill strait crossing the inserted column.
In this case it will be not important , but in other cases it may be.
The column is a alone standing object inside the big bloc (2 solids - not added) and for slicing them separately I use a own process for each one (with only one process for both the column will be ignored).
If there is a way to avoid the crossing, I don't know it, if it is buggy, please cure it.
Thanks
GER
Halter_klein_Test.stl
(181.19 KiB) Downloaded 65 times
