Hi All,
Just checking a coupe of entries here in the forum, I did not find any solution perhaps someone could assist or help to find a solution.
Attached are to Screenshots showing the Problem.
1. from 2019-04-03 at 11.07.33 is showing the unsliced drawing out of Fusion 360 as STL (the Yellow body)
2. from 2019-04-03 at 11.10.24 Is showing the sliced modell and within the 1/3 section from botton you will see that the outer wall is missing
Is there any one who could assist me findeing the error in the slicing process.
The same as in 1. sliced with CURA is without any problems.
I'm using an Ender 3 Pro which is included in the printer list of Simplify3D.
I would like to attach also my settings but I don't know how, because I'm new in 3D printing and the used Software.
Kind regards
Willi
