horst.w wrote: ↑
The fist one E -5.5000 is found in the gcode-line 333,093 of 348,022.
Hi S3D-Jake,
thanks for answering!
I searched for the typical command E-5.5 what indicates retracts.
I'm expecting retractions anytime when the printhead jumbs to the 2nd object, will say, any layer must have two retracts. Forward and backward.
Obligatory every retract must have a Z-lift what is expressed by the command G1 Z.... (+0,6mm / - 0.6mm related to the actual layer height)
When I have found with MS-notepad ++ the first retract it was in commandline 333,093. All layers before I couln'd find E-5.5.
To controle myself I have tested with V 4.0 and notepad++ has found retracts all over all.
I have played a lot with the settings and unfortunately I have over written the origin of the print file on SD card. The attached factory-file and all pictures I took after the print and so they are not origin.
The next few days I have to print them once more, we will see.
