wfcook
Process that starts above bed has incorrect first layer infill
In this factory file, the "bulb" process uses an incorrect infill angle on its first layer.
keel_bulb_try4_075.factory
(871.88 KiB) Downloaded 323 times
Re: Process that starts above bed has incorrect first layer infill
I've looked at this factory.....
First thought....waste of time having one process to print one line at .15mm height, then second process to print remainder at 0.075. But this is only a comment!
The issue is that the second process starting "off" the bed is creating a bridging layer. The code change that makes this happen was applied in v4.1.0...pre-v4.1.0 and normal infill occurs.
If the angle is alli mportant...then applying a bridging infill angle will give a workaround....
