ttn
Re: Gyroid infill
Sun Apr 21, 2019 5:15 am
+1
nuramori
Re: Gyroid fill pattern
Mon May 27, 2019 10:32 pm
I just got Simplify3D, having been using Cura up until now. I had thought gyroid was a basic staple of all these programs, and am a bit shocked that it is not an option with this package. I make parts that require structural strength and stability, and gyroid is a must imho. In fact not knowing that if it will be included in a near future update gives me pause enough to use the 2 week guarantee and just go back to Cura.
MLJ
Tue Jul 16, 2019 2:41 am
+1 *10^10
Judge
Tue Dec 31, 2019 11:23 pm
+1
Aurawin
Fri Jan 03, 2020 10:56 pm
I used to use CURA and I absolutely love Gyroid. It's a torture test of infills. I you can do gyroid without PETG filament snowballing you nozzle you have masted it.
The first thing I did was try to give my prints the same strength I had in Cura. Enter "wiggle". Don't laugh. If you keep rotating wiggle you get a similar construction it's just harmonically nasty to your printer. Give this a try...
1. ) Use a new Extruder config called "Infill". Select your tool index (0)
Whatever multiplier you have for your typical printing the Extrusion multiplier for "Infill" is about 3 points lower. Starvation is better for your test print but watch for filament snowballs.
2.) Goto Infill tab
Select wiggle pattern.
Select "Infill" as your extruder
Add 0,45,90 in both Internal and External Angle offsets
3.) Test print. Increase/decrease "Infill" extruder's multiplier as needed decrease if you blob, increase if the infill isn't connecting with each other or with the walls.
This is what I do and it's been just as good as gyroid. Gyroid was smoother though - but that's the hole point.
ae0mt
Fri Jan 17, 2020 9:52 am
Add me to the list of those interested in seeing this implemented in S3D!
drvertigo
Wed Jan 29, 2020 8:31 pm
+2
S3D: Can you kindly advise if you intend to add this feature?
Thankyou.
