Duckers_McQuack
Sliced model looks terrible.
Top is what it should look like, but bottom is what it shows as. completely broken, why is that?
S3D-Alex
Re: Sliced model looks terrible.
Could you please post the STL or the Factory File? This looks like it is more than likely a model issue but I cannot confirm that without the files. You can also use Repair > Identify Non-Manifold Edges and/or Repair > Identify Self-Intersecting Surfaces to find these errant sections.
See: viewtopic.php?f=9&t=13150 updated a few minutes ago!
Duckers_McQuack
thanks, but i solved it :) Apparently the meshes were broken, and S3D can't handle such like cura can. So i imported every piece into windows 3d builder, repaired from there, then threw it in.
But this dragon won't work. Teeth no matter the layer height won't show.
MasterFX
Link? Factory File? STL?
Duckers_McQuack wrote: ↑Thu Apr 18, 2019 3:03 pm .... no matter the layer height won't show.
Layer Height ??? Layer Width can help perhaps!
GER
S3D-Alex
Depending on the orientation of the model here these teeth may be dipping below the thin wall threshold. I would recommend making sure you have external thin walls turned on. This option is found in the Advanced tab of the Process Settings.
