multimediadesign
Mirror is not mirroring supports
When I hit "mirror X" on object with supports then I think that object with supports will be mirrored. Now mirror is not mirroring supports. I thinks it`s bad becouse If I needs simetrical prints then I need rebuild whole supports structure once again. It`s waste of user time.
Wambidgee
Re: Mirror is not mirroring supports
I would also add my vote to this feature request. If the Mesh > Mirror Mesh command also mirrored the associated support structures, this would halve the time to create the custom supports I often need to generate when working with paired symmetric models - which I work with extensively. For the things I do, the automated support generation tends to produce suboptimal support structures so usually I have to create custom supports. The Edit > Duplicate Models command does a good job of copying the suppports, but if I then mirror the copied model, the support structures remain unchanged.
You've posted a feature request in the Troubleshooting & Bugs section.....best if the Admins move the thread to where is should be.
EDIT....thanks for moving the thread...
Thanks for your feedback. I'll be sharing this feature request with our developers.
