nfol wrote:
Is there a setting that can add some waiting time in after each layer, to not use material for an extra object?
Maybe you can do something like that using the layer change script. But moving the extruder away, waiting and coming
back will probably introduce some ooze problems...
But you can reduce material usage easily: Instead of duplicating the object you can take a small box and scale it accordingly.
Quick example of what I mean. The tower would take ~50cm of material, the benchy around 2.3m in that case. You could
reduce this further by assigning a second process to print the scaled box ("tower") with less shells, no infill and no top
layers.
(Sorry I didn't mention this in the other thread going on - but there was so much going on already...)
bye,
Daniel
