alemaz
Simplify 4.1.1, supports problem
Wed May 22, 2019 5:15 am
Hi, I started using simplify recently and I have some problems with the supports. I read a bit on the forum of problems similar to mine but I did not understand if there is a solution or not. I am attaching photos of my settings and the slice he made. He pretends to print the support in the air, he does it also in other parts of the object. I don't know what to do and I don't know where to put my hand, the only value I tried to change is "extra inflation" lowering it but it doesn't change anything ... Can you give me a hand? I tried to print the piece anyway but it doesn't look good.
In the photos the part highlighted in orange is empty
alemaz
Re: Simplify 4.1.1, supports problem
Thu May 23, 2019 9:58 am
tomorrow I will add the missing photos, unfortunately i failed to put them in the first post
Thu May 23, 2019 11:22 am
A factory file would be 10000000% more useful! Screenshots of partial settings can be hard to read.....and are likely to be useless to someone wanting to help.
