AndyLee
CR-10s pro temperatures not read
Hi. I'm sure I'm just doing something stupid, but S3D is not reporting or logging the temperatures (nozzle and bed) from my CR-10s pro. I'm using the latest v4.1 on ubuntu 14.04 with the printer connected over USB and the CR-10s pro profile selected. I can see the temperature read lines in the comms window, but this does not seem to be recognised. What am I doing wrong? Has anyone else had this problem? It worked fine with my old CTC?
Cheers
Andy
rementicule3d
Re: CR-10s pro temperatures not read
i have the same problem with my cr-10s pro. I try tu use the Tiny machine firmware but no change
Thanks for reporting this! Can you also post an example of the feedback sent by the printer?
j_Barrett
READ: ok ==T:238.00 /238.00 ==B:79.72 /80.00 @:80 B@:127
SENT: G1 X105.626 Y45.453 F2334
READ: ok
SENT: G92 E0.0000
SENT: G1 E-7.4000 F4200
READ: ok ==T:238.00 /238.00 ==B:79.70 /80.00 @:80 B@:127
READ: ok
3Dprinty
Exact same issue here.
Tried various printer FW - no change.
