Lots and lots of stringing.
I'm trying to get Simplify3D tuned in for my Tronxy X5SA and really struggling with a couple of settings.
These settings are for PLA.
Extruder:
Retraction distance: 4.00mm
Retraction Vertical Lift: 1.00mm
Retraction Speed: 9000mm/min
Layer:
First Layer Height: 75%
First Layer Speed: 35%
Temperature:
Extruder 1: 200
Heated Bed: 60
Cooling:
Layer 1: 0
Layer 2 60%
Fan override
Increase fan speed for layers below 60sec
Maximum cooling fan speed 60%
Bridging fan speed override 100%
Speeds:
Default Printing Speed: 5000.0mm/min, I suspect this is way too fast. It had been set to 6000.0mm/min but that caused extruder skipping
Outline Underspeed: 50%
Solid infill underspeed: 80%
X/Y Axis Movement Speed 4800.0 mm/min
Z Axis Movement Speed 1,000.0mm/min
I have the fan speed turned down because between the hot end fan and the part fan speeds higher than 60% prevent my hot end from staying at 200c.
I've replaced the F-Mini board with a Duet 2 Wifi board and other than massive stringing the printer is producing good looking prints.
I've tried but can't find any definitive settings for this printer.
Any help would be appreciated.
Thanks.
