BartofBorg
print not centered to bed
I have a small issue I am not able to figure out. I never noticed it until I started printing larger prints. My models are printing offset from the center. It is printing fine in every other respect. My global offsets and origin offset are at zero except Z axis global which is set to -.05 for better squish. S3D shows the models in the center in preview but when printing, it is offset on the X axis by about 25%. Any ideas on what is wrong here?
Re: print not centered to bed
It'll probably be either the build volume or origin offset in the printer configuration that is not right.
If you've ;loaded a standard printer profile, I'd try reloading it....or if you have a custom printer setting then it needs adjusting.
BartofBorg
You mean in Marlin?
Printer config in S3D is 300x300x350 which is the correct parameters, offsets are all at zero
dkightley wrote: ↑Tue Jun 04, 2019 2:56 pm It'll probably be either the build volume or origin offset in the printer configuration that is not right.
