]The g-code script generated by the Configuration Assistant is as follows:
G28 ; home all axes
G1 Z0.2 F3000 ; get ready to prime
G92 E0 ; reset extrusion distance
G1 X100 E10 F600 ; prime nozzle
It does not return the extruder to the original 0 point and results in the failure of the first layer! The print is beginning .2mm above the correct height,
