wolfelipe
3D EASY LABELING
It would be a LOT easier to enumerate simultaneous configuration tests if we could 3d write under the parts, with negative extrusion, just by adding text on the part configuration menu that appears when you double click the part. I hope you consider it.
Re: 3D EASY LABELING
Thanks for your feature request! You'll find more like minded individuals have already requested something similar here: viewtopic.php?f=23&t=11051
