I have noticed that almost every print I have done since installing S3D-v4 that the print will randomly pause for 1-3 seconds then continue on. It usually will only do this once but I have seen it happen twice on one print job. The weird thing is, reprinting the same model without adjusting any settings may not cause this to happen... it seems totally random. This was not present in the last release and I can not figure out what might be causing it. As expected, the pause causes an artifact to be created at that point in the print and on a couple of occasions has left a large enough deposit of plastic to cause a belt on my delta to skip a tooth, resulting in a layer shift. I did a test and re-installed the previous version and it has not once done this so something in v4 has to be the cause. Not sure if this is a bug or one of the new settings is to blame. Anyone else having this issue? Anyone with any idea on what might cause this?
I have not seen anything in the terminal window at that point to indicate communication error or invalid gcode. Kind of at a loss here....
