i'm beginning to understand that extrusion multiplier, esteps and temperature are really tightly related! i have done a ton of 1st layer tests, .2mm high. i started getting pretty great results with the esteps cranked up above what i had calibrated, i calibrated from default of 95 to 103, but then turned up to 107. i do this under the scripts tab in the start gcode.
also, should i set extrusion multiplier to 1.0 when i am using the esteps? i used the macihne control panel to extrude the 100mm of filament so not sure if that took into account the extrusion multiplier?
in otherwords, maybe setting the esteps and leaving the extrusion multiplier set to the default of .9 for pla and my machine profile is OK? it seems like you can fudge it between esteps and extrusion multiplier?
as far as temps, i see that makes a big difference too, but not as much as extrusion multiplier or esteps.
right now i'm using .9 extrusion multiplier and 107 esteps which i judged by the many 1st layer tests i've done. my wall width is supposed to be .8mm and i'm measuring .84 on all 4 sides - it's consistent great! my nozzle is .4mm and i have its size set to manual and .4mm. although is there some thoughts on using a bit larger nozzle size in the slicer?
i also wonder if extrusion multiplier affects overall layer height, or setting higher esteps for that matter? so over time and height in a tall print the errors could add up and not be good!
sorry, lots to unpack here ha!
thanks,
