an update - this don't properly work... no clue why, no time to debug ... anyhow ..
you import your old FFF part of the key (follow previous post) and your s3d will have all the old configurations, till you reboot computer, after a reboot - s3d fails to start
... anyhow, the good part is, you use this to load your configs, start s3d (before you reboot computer), export all your settings manually (one by one, can take some hours if you have a lot of them
) and then uninstall s3d, remove all s3d registry entries you can find reboot computer, install s3d from scratch, register etc etc... and then load all the configurations manually (another hour or so depending on how many you have... ) .. you can use this time to "clean them up" so export only the ones you really use and then import only those ones hoping you will never need nothing from those you ignore (this is what I did 'cause my hand started hurting from clicking, I migrated only 12 out of 100+ but I think this is actually good, those 90+ were more / less same, experiments or "I don't even know what I tried there - that's why a >>note<< for a config would be cool addon")
so just a heads up ..
I hope s3d will soon implement that "export all settings as archive" with "import a directory/archive with settings" feature so this type of work becomes obsolete
Embed M117 codes into G-Code
open source and unlicence
