S3D-Alex
Re: Creality CR-10S PRO profile
There is now a specific profile for the CR-10S Pro in the software. Just go to Help > Configuration Assistant and select the CR-10S Pro from the drop-down menu.
webdad
When I look at the machine list, I only see the CR10 profile. Is there a CR-10S PRO specific file available? I am still running 4.0.1
webdad
Got it. Had to upgrade to 4.1
Codex404
S3D-Chris wrote: ↑Mon Dec 17, 2018 1:54 pm The CR-10S is functionally similar to the CR-10. We recommend using the CR-10 profile that is available in the Configuration Assistant.
The CR-10S is a different printer than the CR-10S Pro, for me personally the CR10 profile did not do much good to my prints. So currently I'm making it from scratch.
Reilley
Just ordered a CR-10S Max to replace my dead Robo3D R1+ that I can no longer get technical support for. The CR-10S Pro is like the other Pro models, but has a larger build area. Is there a profile in S3D for this one or should I just use the standard CR-10S Pro profile?
Thanks in advance!
pietraspecter
Click on "File" > "Import FFF profile" and choose the best gcode that came in the printer's SD Card. S3D will get the gcode's settings that will be the factory settings. It's always a good profile that needs small amount of tunning. :D :D :D :D :D
