I am doing an upgrade to my FFCP that will have it doing normal gcode communications. So as a result I have added in the FFCP through the configuration assistant and it added this model that should be of part of the machine (probably represents the bed).
I do not want this, so I went into options to remove it - tools / options / machine / printer models / remove.
Yet, when I go into edit process and press okay to close it - the model is back again.
How can I remove this thing permanently?
