tprothma
"Failed to Locate G-Code File for Conversion" for BFB
I get this error with S3D 4.1.2 "Failed to Locate G-Code File for Conversion" . It will not generate a .gcode file for BFB. I use a lot of post processing commands that operate on the .gcode file before it gets converted to .bfb.
In the scripts I have output file format set to .bfb.
This did not happen with S3D 4.0. Although they seemed to have cleaned up some issues with the .bfb conversion in 4.1.2, I need it to process the G-Code file as an interim step as there are details lost if they only output the BFB and many of my "Additional terminal commands for post processing" do not work.
Tim
