S3D-Jake wrote: ↑Mon Aug 26, 2019 11:40 am Thanks for the feature request. Can you be more specific about which keys are being used to store such large quantities of data that is an unacceptable use of said storage location? I'd be happy to suggest a change if I can come to our developers with more information.
Thanks again!
My bad!!!S3D-Jake wrote: ↑Fri Aug 30, 2019 2:59 pm That registry contains the profile database. You mentioned storing table models, last loaded model file, etc... I'm not able to find any of those items being stored in the registry as more than just a reference to the file from which to load these items.
As you said, storing the configurations in the registry is acceptable. That key you mentioned is doing just that, storing your saved configurations.
I'm glad this didn't turn out to be the root of the issue, as I was positive an issue like that would have been reported much earlier in the current release's life cycle. As a bit of more background on the geometry key, it is used to remember Window positions, sizes, and stuff like that. It is what makes the supports menu open in the same place after you've moved it from the default place.arhi wrote: ↑Sun Sep 01, 2019 1:33 pm I was going through it all and I seen few big key entries and I assumed everything is there but actually a big chunk I expect is in "geometry" and some other keys is in .factory file
%LocalAppData%\Simplify3D\S3D-Software\savedState.factory
so everything dandymy bad
