cadkins
S3D not recogizing ID and OD of part
I am trying to print a cylinder with hemispherical dome. after slicing the ID of cylinder is filled as well as blind hole on top of dome.
how to fix this?
sk1978-11_fixed.stl
(1.08 MiB) Downloaded 86 times
Re: S3D not recogizing ID and OD of part
Look on the advanced tab at the bottom right and uncheck "merge all outlines …" See if it helps.
