Hi
I'm pretty new to 3d printing, just started less then a week ago, learning the terms/methods as I go
I've noticed that the Robo 3D R1 handles the bed leveling on the software/firmware level, MatterControl is pretty bad at printing support structures, so I bought Simplify 3D, however MatterControl was able to handle the software bed auto leveling
I think the idea is to measure the z-offsets at different points and reflect those to the G-code computations
Am I right to assume that Simplify 3D doesn't do this, therefore I'm unable to print large objects with Simplify 3D? (I'm manually setting the g-code z-offset to 1,2mm, this enables me to print small objects, however at large objects, there is a 0,1mm, left-to-right level difference, which causes the nozzle to be blocked)
I'm open to any kind of advice in this matter, I'm currently going to print small disks at different intervals, like 0,9mm, 1,1mm, etc and try to manually level the print bed by putting those in-between the heated bed magnets
