Even though the extruder widht is set as 0.8 in the print process and the right extruder is removed, the header still has the following information:
;START_OF_HEADER
;HEADER_VERSION:0.1
;FLAVOR:Griffin
;GENERATOR.NAME:Simplify3D
;GENERATOR.VERSION:4.1.0
;GENERATOR.BUILD_DATE:2018-10-24
;TARGET_MACHINE.NAME:Ultimaker 3
;EXTRUDER_TRAIN.0.INITIAL_TEMPERATURE:100
;EXTRUDER_TRAIN.0.MATERIAL.VOLUME_USED:38266.06
;EXTRUDER_TRAIN.0.MATERIAL.GUID:60636bb4-518f-42e7-8237-fe77b194ebe0
;EXTRUDER_TRAIN.0.NOZZLE.DIAMETER:0.4
;EXTRUDER_TRAIN.0.NOZZLE.NAME:AA 0.4
;EXTRUDER_TRAIN.1.INITIAL_TEMPERATURE:100
;EXTRUDER_TRAIN.1.MATERIAL.VOLUME_USED:0.00
;EXTRUDER_TRAIN.1.MATERIAL.GUID:60636bb4-518f-42e7-8237-fe77b194ebe0
;EXTRUDER_TRAIN.1.NOZZLE.DIAMETER:0.4
;EXTRUDER_TRAIN.1.NOZZLE.NAME:AA 0.4
;BUILD_PLATE.INITIAL_TEMPERATURE:60
;PRINT.TIME:2715
;PRINT.SIZE.MIN.X:40.60
;PRINT.SIZE.MIN.Y:57.10
;PRINT.SIZE.MIN.Z:0.00
;PRINT.SIZE.MAX.X:184.40
;PRINT.SIZE.MAX.Y:158.90
;PRINT.SIZE.MAX.Z:35.00
;END_OF_HEADERCode: Select all
; G-Code generated by Simplify3D(R) Version 4.1.2
; Sep 12, 2019 at 12:46:59 PM
; Settings Summary
; processName,Process1
; applyToModels,432908_1
; profileName,Ultimaker 3 (modified)
; profileVersion,2019-09-10 13:22:07
; baseProfile,
; printMaterial,ABS
; printQuality,Fast
; printExtruders,Left Extruder Only
; extruderName,Left Extruder
; extruderToolheadNumber,0
; [b] extruderDiameter,0.8[/b]
; extruderAutoWidth,0
; extruderWidth,0.8I've tried editing this code in the scripts tab:
{PREPEND ";START_OF_HEADER\n;HEADER_VERSION:0.1\n;FLAVOR:Griffin\n;GENERATOR.NAME:Simplify3D\n;GENERATOR.VERSION:4.1.0\n;GENERATOR.BUILD_DATE:2018-10-24\n;TARGET_MACHINE.NAME:Ultimaker 3\n;EXTRUDER_TRAIN.0.INITIAL_TEMPERATURE:100\n;EXTRUDER_TRAIN.0.MATERIAL.VOLUME_USED:[extruder0_filament_volume]\n;EXTRUDER_TRAIN.0.MATERIAL.GUID:MATERIAL0\n;EXTRUDER_TRAIN.0.NOZZLE.DIAMETER:NOZZLEDIA0\n;EXTRUDER_TRAIN.0.NOZZLE.NAME:NOZZLENAME0\n;EXTRUDER_TRAIN.1.INITIAL_TEMPERATURE:100\n;EXTRUDER_TRAIN.1.MATERIAL.VOLUME_USED:[extruder1_filament_volume]\n;EXTRUDER_TRAIN.1.MATERIAL.GUID:MATERIAL1\n;EXTRUDER_TRAIN.1.NOZZLE.DIAMETER:NOZZLEDIA1\n;EXTRUDER_TRAIN.1.NOZZLE.NAME:NOZZLENAME1\n;BUILD_PLATE.INITIAL_TEMPERATURE:60\n;PRINT.TIME:[total_print_time_sec]\n;PRINT.SIZE.MIN.X:[build_min_x]\n;PRINT.SIZE.MIN.Y:[build_min_y]\n;PRINT.SIZE.MIN.Z:[build_min_z]\n;PRINT.SIZE.MAX.X:[build_max_x]\n;PRINT.SIZE.MAX.Y:[build_max_y]\n;PRINT.SIZE.MAX.Z:[build_max_z]\n;END_OF_HEADER\n\n"}
{REPLACE ";EXTRUDER_TRAIN.0.MATERIAL.GUID:MATERIAL0\n;EXTRUDER_TRAIN.0.NOZZLE.DIAMETER:NOZZLEDIA0\n;EXTRUDER_TRAIN.0.NOZZLE.NAME:NOZZLENAME0" ";EXTRUDER_TRAIN.0.MATERIAL.GUID:60636bb4-518f-42e7-8237-fe77b194ebe0\n;EXTRUDER_TRAIN.0.NOZZLE.DIAMETER:0.4\n;EXTRUDER_TRAIN.0.NOZZLE.NAME:AA 0.4"}
{REPLACE ";EXTRUDER_TRAIN.1.MATERIAL.GUID:MATERIAL1\n;EXTRUDER_TRAIN.1.NOZZLE.DIAMETER:NOZZLEDIA1\n;EXTRUDER_TRAIN.1.NOZZLE.NAME:NOZZLENAME1" ";EXTRUDER_TRAIN.1.MATERIAL.GUID:60636bb4-518f-42e7-8237-fe77b194ebe0\n;EXTRUDER_TRAIN.1.NOZZLE.DIAMETER:0.4\n;EXTRUDER_TRAIN.1.NOZZLE.NAME:AA 0.4"}If i edit the generated g-code like this (removing EXTRUDER_TRAIN.1 lines and correcting EXTRUDER_TRAIN.0 lines):
;START_OF_HEADER
;HEADER_VERSION:0.1
;FLAVOR:Griffin
;EXTRUDER_TRAIN.0.INITIAL_TEMPERATURE:255
;EXTRUDER_TRAIN.0.NOZZLE.DIAMETER:0.8
;EXTRUDER_TRAIN.0.NOZZLE.NAME:AA 0.8
;BUILD_PLATE.INITIAL_TEMPERATURE:85
;PRINT.TIME:2715
;START_OF_HEADER
;HEADER_VERSION:0.1
;FLAVOR:Griffin
;GENERATOR.NAME:Cura_SteamEngine
;GENERATOR.VERSION:4.2.1
;GENERATOR.BUILD_DATE:2019-08-01
;TARGET_MACHINE.NAME:Ultimaker S5
;EXTRUDER_TRAIN.0.MATERIAL.VOLUME_USED:46210
;EXTRUDER_TRAIN.0.MATERIAL.GUID:5df7afa6-48bd-4c19-b314-839fe9f08f1f
;BUILD_PLATE.TYPE:glass
;BUILD_VOLUME.TEMPERATURE:36
;PRINT.TIME:3928
;PRINT.GROUPS:1
;PRINT.SIZE.MIN.X:85.96
;PRINT.SIZE.MIN.Y:61.96
;PRINT.SIZE.MIN.Z:0.53
;PRINT.SIZE.MAX.X:244.04
;PRINT.SIZE.MAX.Y:178.04
;PRINT.SIZE.MAX.Z:34.45
;END_OF_HEADER
;Generated with Cura_SteamEngine 4.2.1
