I set a print with 1 process up to 1.6mm from the build plate and a second for the rest of the print. I tried to print a different part but it still showed two process in the process window so I deleted the second one. Now nothing will print more then 1.6mm high! How do I fix this, Turn it off? Thanks in advance for your help.
Thank you for the help. I learned about this feature from the tutorials. When this happened I when back to the tutorial but there was not a clear answer.
