HugoW
Solid layer half-way, causing splitting
my first post here, so far I got by by googling. I've been 3D printing on a home made CoreXY machine for 3 years now, about a year ago I transferred to Simplify3D. I use my printer as a tool to make car parts, both real and RC cars, and my new project involves stainless tubing so I print some weld els and other items to make a mock-up of the final idea, before cutting and welding any real steel.
Normally, I print els laying down. But since my heated bed relay failed (new one is ordered) I printed one upright. (Never mind the bottom setion, that fits into something else)
Drawn in FreeCAD, exported as STL, loaded in SF3D:
What I notice now but didn't notice when I created the print file yesterday, is the green layer in the middle, a solid layer. I did notice it this morning, however:
If been searching but I cannot figure out why this happens, and how I can prevent it. I'll just hot-glue this together so I can use it, as I hot-glue-weld together the els and tubes for the mock-up anyway, but this problem I want to understand and prevent in the future.
Thanks,
Hugo
Re: Solid layer half-way, causing splitting
S3D is far more sensitive to minute errors in the mesh(es) of shapes it slices....probably why it slices much faster than other slicers. You'll need to run the shape through a repair program to remove the issue(s) that are causing S3D to print the solid layer.
If you are running Win10, then try the app 3DBuilder...which will auto-repair when you load the file. If not, there are online services that will do the job.
