MakerTech LLC
Thin walls not Infilling and Top Layers not sealing
1) Have tried various Advanced setting changes to improve thin wall printing with no visible change.
2) Profile attached.
3) Print image attached.
4) Machine Specifications::
Windows 7 Home Premium 64 Bit
SeeMeCNC Rostock MAX v2 latest Arm, Carriage, and Hot End upgrades
EZRstruder Upgrade
HE280 Hot End
Nozzle ID stamped: 0.5mm
Simplify 3D v4.0.1
Rambo Firmware Repetier 091S
24 Volt 20 Ampere Main Power Supply
Switching Buck Converter to supply Rambo 12 Volt power
6mm thick 6061-T6 Aluminum Build Platform
300 Watt 24 Volt Silicone Round Heater Pad
Solid State Relay to control Heater Pad 24 Volt from Rambo Build Platform Heater Output
Kapton Build Surface
Q: Any suggestions for Settings to change for improved print Top Layer sealing?
ABS 50% on 2 100% Fan.fff
(11.38 KiB) Downloaded 416 times
Re: Thin walls not Infilling and Top Layers not sealing
A FFF-Profil doesn't replace a FACTORY-File!
A factory contains also the STL of the model and this is needed to find out the reason.
Nevertheless try out to set INFILL >>> Minimum Infill Length down to zero (now 1 mm).
You are using version 4.01. If I remember right, this version was a little bit faulty and was replaced by version 4.1 and now we have 4.1.2 (and hopefully waiting to version 5 ;-) )
GER
No answer is also an answer!
I have found this here:
viewtopic.php?f=9&t=14061&p=53135#p53135
You are well knowing what a factory file is, but you avoid to show it.
If you are using a cracked version such like "Licensed for God", than it wasn't a good idea to ask here for help!
Over and out.
H.
MakerTech LLC
Dear Horst;
Thank you for your helpful reply!
"A FFF-Profil doesn't replace a FACTORY-File!
A factory contains also the STL of the model and this is needed to find out the reason."
I have read that the S3D Terms of Service prohibit publicly posting Factory Files, and that specific queries of S3D on this issue were not definitively resolved. Did I misunderstand what I read, or was it just inaccurate?
Can you shed any light on this matter?
"Nevertheless try out to set INFILL >>> Minimum Infill Length down to zero (now 1 mm)."
We tried from 5mm down to 2 then to the 1 reflected in our Profile with no visible improvement. I'll go take that further step now and report back here. Thanks for motivating me ;)
"You are using version 4.01. If I remember right, this version was a little bit faulty and was replaced by version 4.1 and now we have 4.1.2 (and hopefully waiting to version 5 ;-) )"
Our Machine Specifications text was incorrect - the tests were all made using S3d V4.1.2 :(
Again, thanks for your courteous and helpful response!
MakerTech LLC
Dear Horst;
Checking with my associate revealed that we had indeed tried the 0.00mm Minimum Infill Length setting.
Thanks!
MakerTech LLC wrote: Tue Nov 26, 2019 4:18 pm
The restriction is only available for those factory-files when copyrights of the models are concerned.
H.
MakerTech LLC
This post SHOULD now provide all data needed to diagnose the problem previously described:
1) Machine hardware/software inventory attached;
2) Closeup image of defective print attached;
3) Factory file of print in image attached
Any assistance appreciated.
• Windows 7 Home Premium 64 Bit
• SeeMeCNC Rostock MAX v2 latest Arm, Carriage, and Hot End upgrades
• EZRstruder Upgrade
• HE280 Hot End
• Nozzle ID stamped: 0.5mm
• Simplify 3D v4.1.2
• Rambo Firmware Repetier 091S
• 24 Volt 20 Ampere Main Power Supply
• Switching Buck Converter to supply Rambo with 12 Volt power
• 6mm thick 6061-T6 Aluminum Build Platform
• Kapton Build Surface
• 300 Watt 24 Volt Silicone Round Heater Pad
• Solid State Relay to control Heater Pad 24 Volt from Rambo Build Platform Heater Output
Cornucopia CL2 SAMPLE.factory
(38.85 KiB) Downloaded 277 times
All that was needed was the factory file. Everything else was a waste of time!
I spent two or three minutes tweaking the bottom profile in the list....and it will probably print okay now.
(38.83 KiB) Downloaded 239 times
MakerTech LLC
Thanks, Doug.
Turns out I *STILL* didn't supply enough data - we don't use the bottom profile for that print, but the one near the middle named "ABS 50% on 2 50% fan".
Can you list and describe what tweaks you made?
Your assistance is most appreciated!
