hello. i have recently started to experiment with multiple processes. my factory file won't attach because it is 15mb in size (how could i reduce that? or get you what you need?)
my steps were this:
1. i loaded up my model
2. used the tools > custom support structures to add supports and then remove supports i did not want
3. used slice tool to figure out where to adjust my infill settings, i wrote those heights down in notepad example: 0-20mm, 20-40mm, 40-45mm etc... and came up with 7 processes in total
4. my initial process did not have supports enabled, and so none of the other processes had supports enabled - however when i choose prepare to print, i got a message about enabling the supports
when it finally processed, the support settings under "support" > "automatic placement" did not match what i had created using the tool (except i think "from bulding platform ony".
when it processed, it processed with supports going up the left side of the boot to the strap. the only supports i wanted were under the sole and in the custom support tool, everything that was not under the sole was deleted.
am i approaching this wrong? how do custom supports work with multiple processes?
thanks
