nfol
Peak won't be good.
PLA max, Flashforge Dreamer
I struggle with printing these pyramid peaks, but they get deformed.
The width at the top should be 2 mm, but it collapses, is stretched or whatever in a deformed way.
It does not help to lower the temperature to 190 C (which gives more strings between the objects). Nor to print two objects and run with max fan.
The objects in the factory file attached are just the tips of higher pyramids. The infill is set to 90%, but is not printed so far up the objects. Maybe that is part of the problem?
I very much appreciate any good hint.
Best regards
Niels
Pyramid-eksp.factory
(5.7 KiB) Downloaded 173 times
