CptBraddock
XYZprinting da Vinci mini w+ issues
Hi! I'm having some problems getting my XYZprinting da Vinci mini w+ to work with simplify3d. The problem is that, whenever I try to begin a print, I get an error message saying, "Incorrect file format: XYZprinting .3w files can only be uploaded to Da Vinci brand printers." I have no idea why I'm getting this error.
The printer is hooked up properly; I can connect to the printer using the machine control panel.
I am using the 'XYZprinting Da Vinci Mini' profile and I am using stock firmware.
Does anyone know what is happening and how to fix it?
Interesting note:
I have tried saving the print to disk and loading the .3w through XYZmaker but the imported .3w has a lot of meta data errors and it will not let me print. Upon inspection, with a text editor, the .3w generated from simplify3d is very different from the .3w generated from XYZmaker. Attached are the two files for comparison.
XYZmaker generated.3w.txt
(380.3 KiB) Downloaded 177 times
simplify3d generated.3w.txt
(657.48 KiB) Downloaded 208 times
