brashendeavours
Material/Print Quality settings grouping
Mon Jan 06, 2020 12:33 pm
In the UI there are dropdowns to configure both Material and Print Quality.
It is not straightforward for the user to know what settings are being saved/configured when selecting each of the dropdowns, and worse which settings are being saved by each.
Descriptions:
Material: Automatically configure temperature and extrusion settings for the selected material.
Print Quality: Automatically configure layer height, infill percentages and other related settings for the selected quality level.
This request is for a better UI presentation of what settings are being configured/saved by Material/Print Quality.
The change could be in the form of:
[*] grouping of tabs under Material and another grouping under Print Quality (settings not saved by either could be ungrouped tabs)
[*] annotation by color or asterix (double asterix) to indicate which settings are saved by Material (Print Quality)
Thanks for listening! Great product!
Re: Material/Print Quality settings grouping
Wed Jan 08, 2020 2:34 pm
Great feature request! Another user took the time to describe how this can be done right now. viewtopic.php?f=8&t=5977&p=25950#p25947
I'll document this a request for more of a polished solution, rather the workaround mentioned above.
craftyham
Sat Apr 25, 2020 10:54 am
Possibility something like this?
E3P,E3Mini1.2 bl_touch Custom Micro Swiss with a Copper E3DV6 block & 50W heater Capricorn PTFE tubing PEI flex sheet or glass Solid bed mount Trammed to 0-0.1mm.
SD3-awaiting rebirth.
