Just to see where my printer sits for Temperature on this filament, I printed a Temp tower and it would not even extrude anything less than 200C. I reprinted the piece that I posted above using 205C as a temp and it made it worse. Not only did it come out with extra warping, it also came out rather porous.
Because this is PLA+ I am understanding that the temperature needs to be higher based on the other mixes that are built in to the filament. As a result, I figured that because the filament and adhesion failed at lower temps, higher temps might be the way to go. Afterall, thats the way the Troubleshooting guide explains it.
If you know of any other tips and tricks I might be able to implement, I would appreciate the help.
