So far I have tried a couple of prints and the biggest problem I have is learning Simplify3d. lol I had a good print then I tried another and the print head packed it's bags and ran away from home. It went to the staging corner opposite home and tried to keep going causing the belts to jump a bit until I canceled the job. The first print went real well using the left head for support and the right for the rest of the job.
I'm pretty sure it was operator error. I think I had exited from Simplify3d after finishing the first print and then re-opened it for the second. After the second print failed before start I went back and the FlashForge Dreamer.frm wasn't listed in the firmware config. Apparently I need to import it each time I run Simplify3d.
Is there a way for Simplify3d to store the FlashForge Dreamer frm profile? I hit save but it's gone after a restart. This is on Linux Mint 17 if that makes a difference.
Russ
