Hi, guys !
I am trying to print a mold with single vertical cut of one polygon width, but manifold processing don't allow me to do it correctly. Different setting leads to non-desired results: some polys are disappear when "Discard" option is set or new unwanted polys appear when "Heal" is selected.
Could you please help me to prepare this print correct way ?
BTW: Can not figure out why this surface is detected as "non-manifold" ? All normals are pointing to the same direction if we will "unfold" the model.
Thanks in advance.
