To insert pauses (or anything you want) for changing filament S3D supports using the REPLACE command in the post processing scripts tab, which is good.
However, I'd like to be able to output literal double quote characters (") in the replace text (to have the printer display a text). Some printers accept text added to the pause command, example:
M25 "Change to RED"
However, the double quotes surrounding the text interferes with the replace command, so this doesn't work. Escaping the double quotes (with a \) doesn't work either.
Is this possible, or is an external text tool needed to achieve this (not difficult to do, but built-in is preferred when possible)?
