doncarrick
settings question
Hello,
Is it possible in the Simplify settings to set the speed for printing the inner and outer perimeters to be the same but not equal to the maximum?
The perimeter is printed from the inside out. The inner thread is printed at the default speed, the outer (outer) speed is lower, which is set in the Other - Outline Underspeed tab.
I need all the threads of the perimeter to print at the same speed - slow.
Thanks
https://gaypornmoviestube.com/
airscapes
Re: settings question
Never have had to do anything like that, but you could set the main speed for the inner perimeter, set the outer to 100% then set the infill to 300% or something that gets you want you want for the speed of the infill
S3D-Chris
airscapes wrote: Never have had to do anything like that, but you could set the main speed for the inner perimeter, set the outer to 100% then set the infill to 300% or something that gets you want you want for the speed of the infill
The infill speed is the default speed and there is no percentage modifier for infill speed.
airscapes
S3D-Chris wrote: Fri Mar 06, 2020 9:44 am
sorry was looking at solid infill under speed (v 4.01)
To the OP try the Prusa slicer it is much more configurable for speed than S3d and it is free.
