crazybear
Missing Infill
Hello,
I designed a calibration pattern object and when I slice it in Simplyfy3D there is a detail that does not have infill. Whoever if I slice it in Slic3r the same area it is filled. I printed the part just to confirm and yeap, there is no filling (Images and factory file attached).
Thank you in advance for your help.
CB
CalibrationPattern8n.factory
(31.1 KiB) Downloaded 214 times
Re: Missing Infill
Mesh menu==>Separate Connected Surfaces. Click it! Problem solved….
Now the long bit...the explanation. The .stl file has multiple meshes...caused by CAD package. & S3D does not like multiple meshes.
crazybear
Re: Missing Infill
Sweet! Thank you! That did the trick. Now the question is... how did you know? Most of the post I found mentioned to change infill settings, extrusion with, nozzle diameter, etc.
Re: Missing Infill
...by understanding how the package works! Simple as that!
